found on cnet:
A motherboard with embedded Firefox
By Rafe Needleman – October 10, 2007, 6:08 PM PDT
I just got a chance to try out a Webware PC: a computer built around the new P5E3 Deluxe/WiFi-AP motherboard from Asus. What makes this motherboard be hardware for Webware is that it has a Firefox Web browser (running on an embedded Linux operating system) burned into ROM. It also has Skype. You turn it on, and in fifteen seconds (I timed it), you can be in Firefox and surfing the Web.
You can also boot it into Windows, or whatever OS you have installed on the hard disk. Boring.
This built-in browser has a lot of great things but some drawbacks too.
In the plus category: This alternate operating system, provided by DeviceVM to Asus, is fast and convenient. There's no giant OS to boot before you get into your browser, which is a slimmed-down version of Firefox, not some weird, quasibrowser that doesn't do what you want. There's a Flash plug-in installed so most modern sites render properly. Flash videos play just fine. The system saves all your settings (including bookmarks) in memory, so you don't have to start from scratch every time you fire it up.
The P5E3 motherboard has nearly everything built in that you'll need. Connecting to a network--wired or WiFi--is fast and easy. Skype has access to the board's audio in and out ports.
Because the DeviceVM platform doesn't have access to the hard disks connected to the motherboard, the system is very secure. So if, say, guests wants to use your PC to check their Web mail, you can boot them into the ExpressGate environment (that's what Asus calls it) and not worry about them junking up your PC. You might want to clear your private data from the Firefox cache first, though.
The browser works just like Firefox. Because it is Firefox.
And this motherboard is "green," at least in theory. Many people leave their PCs on all the time, because launching a browser from a cold PC can take several minutes. With this setup, you can turn off the PC when you're done browsing, and when you need to get back online, you can be there in seconds.
If you work primarily online--using browser-based tools like Google Docs for productivity, Salesforce.com or Basecamp for business operations, Meebo for IM, and so on--this setup is just great.
Should you get one of these motherboards just for its ExpressGate feature, though?
No. As cool and useful as ExpressGate feature is, the Asus P5E3 is the wrong product for it to be embedded in. This motherboard is at the top of the Asus line and costs $350 in a market where most other products are under $200. (To be fair, the motherboard is loaded with high-end features and technology). So forget using this product for cost savings. Since it's such a powerful mobo, it's going to be built into high-end PCs, most likely with high-end graphics cards and kilowatt power supplies that will obviate the potential power savings from the lightweight, instant-on operating system.
And it doesn't support Firefox plug-ins and add-ons, which is a drag.
I spoke with DeviceVM execs Sol Lipman and David Speiser, and I think they recognize the mismatch of their technology and the first product that carries it. However, the P5E3 isn't the only motherboard that will carry their embedded OS and browser. In the first quarter of 2008, we'll see laptops with the embedded browser, which is where it's really needed, and we should also start seeing it in less-expensive desktops.
more at http://www.webware.com/8301-1_109-9795472-2.html
might as well be Internet Explorer thenOriginally Posted by ahhaa
the add ons etc are the beauty and awesome power of Firefox 8)
This means that you will have to start afresh every time or does it mean something else (ram = volatile, harddisk = non-volatile)The system saves all your settings (including bookmarks) in memory, so you don't have to start from scratch every time you fire it up.Corned beef is now made to a higher standard than at any time in history.
Does MSI make anything similar? ASUS have ceased being a good mobo manufacturer for some time now....
